2005 Chrysler Crossfire Car Has Strong Battery - will not s
49,000 MILES • 6 CYL • 2WD • MANUAL
BLUEFEATHER
this car has a Sentry Key Fob Transponder and all that I did was get out get the mail and engine will not start. Is there a reset for the LOCK OUT feature this car has. the lock out feature will not allow the car to be started. this has happened to me twice. I unlock car get in put the key in the ignition and NOTHING. Battery is Strong. Is there a computer clearing code that I can use... I did try unhooking the battery to try to reset the computer... this worked the first time but not this time,,, Help please
Mar 7, 2010 at 8:46 AM
SRTFAN
There is a known issue regarding a starting problem. There is a relay module in the engine compartment that can have bad solder points. They can cause an intermittent or permanent starting problem. The module can be relpaced or repaired.
https://www.2carpros.com/makes/chrysler/crossfire
Mar 7, 2010 at 1:29 PM
