Change the motor in a 1999 f150 to a 1998 f150
4.2L • 6 CYL • 2WD • AUTOMATIC
TONYAT
Can you switch a motor in a 1999 f150 to a 1998 f150 if so what problems do you have
Mar 28, 2014 at 1:45 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
They should switch fine just make sure they have the same flex plate bolt pattern. Being made in the same plant is also a good idea electrically, i.e. the computer and sensor plugs compatability
Mar 28, 2014 at 6:52 PM
