Can you switch a motor in a 1999 f150 to a 1998 f150 if so what problems do you have
Mar 28, 2014 at 1:45 PM
KNOWLEDGE IS POWER
EXPERT
They should switch fine just make sure they have the same flex plate bolt pattern. Being made in the same plant is also a good idea electrically, i.e. the computer and sensor plugs compatability
