Change spark plugs now will not turn on it only cranks?
2005 NISSAN MURANO
185,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JUJU157
  • 7 POSTS
Change my spark plugs and not light and everything turns on but only cranks car won't turn on fully.
Jun 24, 2023 at 3:26 PM
JUJU157
  • 7 POSTS
Change my spark plugs and car won't turn on ...only cranks.
Jun 24, 2023 at 3:28 PM
  • 110,244 POSTS
That is odd. When it cranks, does it give any indication it's trying to start? Also, keep in mind, most crank no-start conditions are usually a fuel-related issue or ignition spark. Since the plugs were just replaced, I need you to check if they are getting spark.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, if you have a scan tool, check to see if there are diagnostic trouble codes stored. If there are, let me know what they are.
If there is no spark to the plugs, check fuse 77 in the intelligent power distribution module (IPDM) under the hood on the passenger side.
Jun 24, 2023 at 3:37 PM
JUJU157
  • 7 POSTS
It looks like it wants to turn on but it does not, and I don't think it's getting spark.
Jun 25, 2023 at 12:45 AM
JUJU157
  • 7 POSTS
It's getting spark .... mm I just found out gas can go bad in over 3 months. My car has been sitting with a full tank for 5 months now. I believe that's the problem now. can I get advice before draining it? Or I'm I wrong?
Jun 25, 2023 at 12:38 PM
  • 110,244 POSTS
Try this: First, see if it starts with starting fluid. If it does, then we can assume it is fuel related. However, five months isn't long enough for it to get bad enough to prevent it from starting. At least I've never experienced that as an issue.
If it does start and then stalls, we need to check a few things that are fuel related. Try that and let me know the results.
joe
Jun 25, 2023 at 2:59 PM
JUJU157
  • 7 POSTS
I mean it's been 5+ months not ever sure on how long but it could have been a little past 6 month sitting and like 2 days ago. had the old spark plugs on the front and it did turn on nicely then I'll put it on D then shuts off ...
Jun 26, 2023 at 12:44 AM
JUJU157
  • 7 POSTS
And yeah, I put starting fluid nothing, just cranks and tries to turn on.
Jun 26, 2023 at 12:52 AM
  • 110,244 POSTS
Was there a change when starting fluid is used? Also, is it possible for you to record it cranking and upload it for me to hear?
Jun 26, 2023 at 2:22 PM
JUJU157
  • 7 POSTS
Hey, you got a number I can call you at and send you videos? It's not letting me upload and no and btw I empty the old gas and put new one still same.
Jun 27, 2023 at 9:54 AM
  • 110,244 POSTS
I'm sorry, but I am required to do everything here online. As far as the video, what type of file are you trying to upload?
As far as the fuel you removed, I had a feeling that wasn't the cause. If you would have said it sat for 2 years, that would be different.
Also, was there any change with starting fluid? If there wasn't, did you check for ignition spark at the plugs?
Also, videos take a long time to upload over Wi-Fi. Could that be the issue?
Jun 27, 2023 at 12:17 PM
