Change oil pan gasket
151,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
SEAN SIR-ROXIXTY BUELL
Have leak and I need to change gasket. do I need to remove the engine to get it off or how do you drop it?
Jan 21, 2017 at 5:59 AM
DOCFIXIT
  • 18,828 POSTS
No need to pull engine will drop down just need to remove radiator core support, cooling fans A/C comp strap out of way. Then remove A/C mount, structural collar then remove inspection shield from transmission drain oil unbolt and drop pan.
Jan 21, 2017 at 6:26 AM
