Change oil light
2014 DODGE CARAVAN
94,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
PAPET
  • 105 POSTS
Yesterday, after starting my vehicle the change oil light went on and disappeared after a few seconds. Today, I went for an oil and filter change but then again after starting the change oil light went on and disappeared. I tried to reset by pressing the gas pedal but still it comes on at start up and disappears. What must be the problem or reason why the change oil light comes after startup? Thanks and hoping for your most appreciated reply.
Apr 1, 2021 at 5:10 AM
I-SMOGEM
  • 118 POSTS
Hi PAPET,
Oil Change Light Reset Procedure for 2014 Dodge Caravan
Be ready to 'fully' press gas pedal. Then:
Turn the ignition to the “RUN” position (do 'not' start).
Immediately press and release the accelerator pedal 3 times (only 3 times) within 10 seconds.
Turn the ignition off.
That is the procedure to reset the Oil Change light.
As far as it coming on at start-up after that, it may simply be part of the lights that come on at start-up (??), and like most things, it may take a few try's to get it to actually reset.
Glenn
Apr 1, 2021 at 11:18 AM
PAPET
  • 105 POSTS
Thanks for your reply and I was able to reset it. I have one more question. Can I use power steering fluid instead of ATF? And is there any damage done in the steering system if I use power steering fluid? Thanks.
Apr 1, 2021 at 4:41 PM
I-SMOGEM
  • 118 POSTS
1) Can I use power steering fluid instead of ATF?
In the transmission? No!
2) And is there any damage done in the steering system if I use power steering fluid?
In place of ATF? Possibly, if the recommendation by the manufacturer is to use ATF, then I would stick with what they say to use.
Some power steering systems need Dexron, or a Dexron like substitute, or other similar types of ATFs - while other car manufacturers are specific about using fluids that are specialized for the steering fluid system but have slightly different properties.
Both fluids, however, have similar seal materials that resist the breakdown of hydraulic fluids. It is always better to follow your manufacturer's instructions about using the various fluids in your car. Sometimes if you can't find a specific fluid, the auto parts store usually has a compatible power steering fluid substitute.
Glad to help: Glenn (oh, and Thanks for the "Thanks")
Apr 2, 2021 at 11:26 AM
