After changing the oil, oil filter and the air filter, the transmission shifts into drive but the car does not Move?
200 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CHRISSCOTTO
I just changed my oil and oil filter, also the air filter on my car. Well, it starts and shifts into gear but won't move in drive, it reverse. Can you help?
Jun 17, 2023 at 1:54 PM
  • 110,248 POSTS
You are referring to the engine oil, correct? If that is correct, I can't imagine what could have happened.
When you place it in gear, do you feel a load on the engine that indicates it is in gear? If you place the vehicle in neutral, are you able to move it?
Jun 17, 2023 at 4:11 PM
