Brakes were grinding change pads now no brake pressure tried bleeding them still no pressure and power steering line leaking
Mar 31, 2015 at 3:46 AM
HMAC300
✓Experienced Mechanic
if the brakes were grinding hope you replaced or turned the rotors. have a pro try bleeding with his scanner so he can open abs valves. at same time. IT may take up to 3 quarts or more to get it to work.
