change brakes now no brake pressure and power steering line leaking
2.4L • 4 CYL • 2WD • AUTOMATIC
RUDY9171
Brakes were grinding change pads now no brake pressure tried bleeding them still no pressure and power steering line leaking
Mar 31, 2015 at 3:46 AM
HMAC300
  • 48,601 POSTS
if the brakes were grinding hope you replaced or turned the rotors. have a pro try bleeding with his scanner so he can open abs valves. at same time. IT may take up to 3 quarts or more to get it to work.
Mar 31, 2015 at 5:14 AM
