blower motor replacement
1999 DODGE DURANGO
2,000,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
PETER KATRAKIS
How do I change the blower motor?
Aug 17, 2017 at 12:59 AM
  • 55,224 POSTS
It looks like you must remove the heater plenum to remove it. I would look to see if you can cut something and then repair it to make the job easier. Here is a guide and some diagrams (Below) so you can get the job done.
This will show you how to test it.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
you will need to vacuum the ac down and recharge it.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Here are the diagrams (below).
Please let us know what happens so it will help others.
Cheers, Ken
Aug 17, 2017 at 9:08 AM
