Fuel filter replacement instructions needed
1,133,444 MILES
ASHLEY LUNA
How to change fuel filter?
Dec 8, 2020 at 1:15 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view showing how to change a fuel filter:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
I've attached picture steps below on how to change the fuel filter on your vehicle. Hope this helps and thanks for using 2CarPros.
Dec 8, 2020 at 1:40 AM
ASHLEY LUNA
Where is the fuel filter located?
Dec 8, 2020 at 3:35 AM (Merged)
BMDOUBLE
  • 1,139 POSTS
Here you go! Under the left rear of the vehicle. Here is a guide that can help as well:
CAMPITES
How often should a fuel filter be changed? Thank You
Dec 9, 2020 at 6:14 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
there is no certain specified interval for replacing your vehicle's fuel filter. only if you experience fuel system issues should you replace the fuel filter.
WORKYANK
Where is my fuel filter location?
2CARPRO JACK
  • 11,533 POSTS
It is under the car near the fuel tank, drivers side here is a guide to help walk you through the service with the location of the fuel filter below.
ED ARMES
  • 129 POSTS
Thanks for this post I love this site.
DUKE6011
Where is the fuel filter located on a 1999 Buick Park Avenue Ultra? Im trying to find it so I can replace it with a new one
Dec 9, 2020 at 6:15 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1999_buick_park_aveune_ultra_fuel_filter_location_1.jpg
The fuel filter is located along the LH frame rail. There you go.
DCKELLEY
  • 125 POSTS
What size is the fitting that goes into the end of a standard (car listed above) fuel filter?
SCGRANTURISMO
  • 4,897 POSTS
I have included all the information that I have on your vehicles fuel filter and fuel line quick connect couplers in the diagrams below. I hope this helps.
Thanks,
Alex
2CarPros
DCKELLEY
  • 125 POSTS
The other end. Would that take a 16mm fitting?
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Sorry about that. It is 16mm X 1.5.
Thanks,
Alex
2CarPros
DCKELLEY
  • 125 POSTS
Thanks. :)
  • 75,988 POSTS
The fuel filter is located under the car on the drivers side rear almost under the rear seat here is a guide to help walk you through the steps and a diagrams to show you on your car. https://www.2carpros.com/articles/how-to-change-a-fuel-filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff_18.gif
Please let us know if you need anything else to get the problem fixed. Cheers
NESELYNS
Engine Performance problem
1997 Buick Park Avenue 6 cyl Wheel Drive Type unknown 113,00 miles
Where do you locate the fuel filter??? Can't seem to locate the darn thing anywhere in the engine???? Denise
Dec 9, 2020 at 6:17 AM (Merged)
DENNYP
  • 1,824 POSTS
Under the car at the left rear wheel area.
https://images.2carpros.com/forum/automotive_pictures/102900_f1_1.jpg
KINGLY7
Where is the feul filter located on a 1987 Buick Park Avenue.
Dec 9, 2020 at 6:18 AM (Merged)
KINGLY7
I found out myself, I was told the feul filter was on the passenger side,mid way down,by an auto parts worker and even a repair manual, both of them were wrong.
The feul filter is located on the drivers side,just under the back door area.
Thanks anyway everyone,kingly7
DAGHPARK
  • 6 POSTS
i wanna know the symptoms of a bad fuel filter
Dec 11, 2020 at 4:09 AM (Merged)
KHLOW2008
  • 41,812 POSTS
A clogged fuel filter would result in loss of power, more noticeable at higher engine rpms.
