Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Eurovan
Steering
Steering Wheel
Cover
Replace/Remove
replacing ignition, how to remove lower cover from the steering wheel?
1997 VOLKSWAGEN EUROVAN
105,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
HONKIE
MEMBER
1 POST
Unable to get lower cover from steering wheel.
Dec 5, 2023 at 5:49 AM
Experienced Mechanic
If the upper cover is removed, it should come off. Did you remove all screws that hold it in place? I attached a pic below. Take a look at it and let me know if that is what your column looks like and if all screws are removed.
See pic below.
Image (Click to enlarge)
Dec 5, 2023 at 10:31 AM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
