Chain noise
8,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SEAN0399
  • 8 POSTS
I keep getting a chain sounding noise from the front end and rear end. I think it is coming from the front end and I am hearing it from the rear end. When I hit a bump it sounds like a chain is just swaying like how you put them on a trailer. I know the shocks are bad all the way around, but I do not know if that is the cause of the noise. Any suggestions. Thanks.
Jul 26, 2016 at 12:26 PM
HMAC300
  • 48,601 POSTS
check your transfer case as that has a chain in it. it may be ready to break also check u-joints front and rear.
Jul 27, 2016 at 12:16 AM
