Central Locking ( can't program FOB )and glove box lamp not working.
160,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
TMC2014
Fuse 38 is good....I suspect the auxiliary fuse/relay box...what relay/fuse might get things working again ?
Followed all the various programming techniques... none worked...thinking if relays/fuses are good only a VCDS Link-up will work for programming FOB ?
Nov 1, 2014 at 8:45 PM
F4I_GUY
  • 3,302 POSTS
There is a certain procedure us VW techs use to program fobs which involve a VAG or VAS scan tool. You must erase the current value stored and relearn the new FOB.
Dec 3, 2014 at 9:46 PM
