Cannot Central lock and set the alarm using the remote-control key?
32,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
IVAN MCDOUGALL
I can't Central Lock and set the Alarm using the remote control key. I have charged the batteries (Engine and Consumer) and replaced the remote key batteries also, but nothing happens when I press the remote any of the 3 buttons. the remote light (red) does come on, on the remote.
Mar 9, 2025 at 7:41 PM
  • 55,694 POSTS
The remote is bad if the red light does not come on which is common. Here is a replacement which you can reprogram for $29.00 from amazon:
https://amzn.to/3FfrYVI
The instructions are included with the new fobs. Please let us know what happens.
Mar 10, 2025 at 6:00 AM
IVAN MCDOUGALL
Hi Ken L, I did say the red light comes on as a process of elimination but I'm delighted to know I can get a replacement from you.
Mar 10, 2025 at 3:10 PM
IVAN MCDOUGALL
Sorry, I should have added to the last post that I am still without a solution.
Mar 10, 2025 at 3:22 PM
  • 55,694 POSTS
Opps, sorry read it too fast. I would check the fuses #16, # 5 and #6 in the trunk for the security system and if they are okay let's do a CAN scan, this video will help:
https://youtu.be/u-4syLc-ifQ
Here are the wiring diagrams for the system. Here are the fuse locations. Check out the images (below). Please let us know what happens.
Mar 11, 2025 at 5:38 AM
