Central locking
AMANDA F
Both back doors do not respond to central locking system. Is this normal for this car or is there some other reason for it? Front doors respond as expected when locked both by key and by button on fob.
Apr 25, 2013 at 11:53 AM
  • 31,937 POSTS
May be a problem with the body control module, scan the system and see if there are any fault codes first.
Apr 26, 2013 at 8:55 PM
AMANDA F
Thank you for quick response. Not being mechanically minded & only on a student income (so as not to afford a mechanic here to take a look), I am not sure what you mean. In laymans terms please, what does a BCM look like & where do I find it?
Apr 27, 2013 at 10:48 AM
  • 31,937 POSTS
The BMC is a small electronic control module, you will not be able to anything with it unless you have a scanner that can read it.
Apr 27, 2013 at 11:51 AM
