Central junction boc in regards to the general electronic module
2001 FORD MUSTANG
5.0L • V8 • RWD • MANUAL
KEITHTAYLOR442200
i have a 2001 mustang with an engine swap. 5.0 ltr from the previous chasis the sn95. well certain electronic funtions are not working ie the trunk release button. the power door switches the door alarms and the reverse lights on the tilight. after troubleshooting and looking at wire diagrams on both generations i found out that the GEM is supposodly bad on my 01. so i first checked the fuse well thats where the problem comes in the fuse junction box was replaced with the previous generation with the engine and the previous generation does not have a GEM on any models so that got me wondering. which one is the problem. i cant find any diagrams of the central junction box on either generation. it had me wondering that the central junction box may be the issue but how would i go about changing the box?? any advice on any option would be grateful
Mar 24, 2015 at 8:21 PM
HMAC300
  • 48,601 POSTS
unless you install the wiring harness for the 01 this will not work. all computer sensors on 01 engine MUST be hooked up as well.
Mar 25, 2015 at 1:32 AM
KEITHTAYLOR442200
So the central Junction box was replaced because the engine swap was from an sn 95? Not the new edge. So how should I go about fixing my issue which is the power door locks and the trunk release latch
Mar 25, 2015 at 1:35 AM
HMAC300
  • 48,601 POSTS
you need the same system from an 01 not a 95 otherwise it won't work that is probably why your windows and trunk release don't work not won't til you put the correct box and harness in
Mar 25, 2015 at 2:25 AM
