Center armrest cover removal
96,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
STRIV59
I removed the center armrest lid fron the center console with no problem. Question: How do you remover the cover from the plastic bracket or housing it rests upon. I want to recover mine with leather. I did it about 5-6 years ago but the leather covering is worn out. Thanks!
Oct 2, 2019 at 3:57 PM
SCGRANTURISMO
  • 4,897 POSTS
Is there screws on the bottom where the leather wraps around and it is held in place? If not it is probably held down with adhesive and will need to be gently pulled away from the lid with a razor blade or some type of cutting tool.
Thanks,
Alex
2CarPros
Oct 3, 2019 at 3:22 AM
