Check engine light, code P0420
190,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
CHARLIETACOS
There is an exhaust leak on the car, it is audible driving at 5-10 mph or 65 mph next to a wall.
Check engine light returns P0420. O2 Sensor 1 reads 2.2-2.7V and O2 Sensor 2 fluctuates greatly.
Question: can the exhaust leak causes both O2 sensor to return such results?
Is my O2 sensor faculty? Is my catalytic converter bad?
Thanks.
Jun 16, 2019 at 5:19 AM
Good afternoon,
The sensor is reading correctly.
When the rear sensor fluctuates, it is indicating the cat is not doing its job.
I would have the exhaust leak repaired first and then check the readings again. If they are the same then It needs a new catalytic converter.
Jun 16, 2019 at 8:04 AM
