Check Engine light flashes ten times KOEO after the ignition light goes out?
260,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
CRAZYDOG72
  • 13 POSTS
The CEL flashes 10 times KOEO after the ignition light goes out. Is this an indicator of a misfire?
Nov 10, 2024 at 12:17 AM
STEVE W.
  • 15,381 POSTS
No. The 10 flashes on a Chrysler product indicates that the emission monitor tests have not run fully. If the battery was just replaced or someone cleared the monitors while erasing a code it will flash that way. If none of those have occurred, then it's possible that the power to the ECM that keeps that in memory has an issue.
Nov 10, 2024 at 12:59 AM
