When all codes are eliminated check engine light stays off while running will it flash one single time when you initially turn ignition key on.
Jul 19, 2019 at 9:21 PM
BMDOUBLE
✓Experienced Mechanic
Yes that is normal, if I understand you correctly. Get in, start the vehicle, cel light initially comes on then turns off, normal operation, it is a prove out for the warning lamp.
