CD4E identifying transmission parts in picture
160,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
MR.HONDA24
  • 39 POSTS
First two pictures I’m trying to find which port this filter (in second picture) went into? It fell out upper right of where my finger is pointing. is it necessary for this cone filter to go back in?
Another thing I need help identifying a part # in third picture (#4 seal) for accumulator main control. I’ve had hard time matching up the o-ring for correct size.
May 22, 2019 at 9:58 AM
  • 55,548 POSTS
The part is a inline filter. can you look for wear marks inside the ports? it should have left a mark inside the port it fell out of. We don't have anything that shows that filter. is it in the case or valve body?
May 26, 2019 at 6:46 AM
MR.HONDA24
  • 39 POSTS
I think it may have fell out of the converter clutch bypass, not from valve body.
Ken, can you tell me which manual transmissions where paired with Duratec 2.3l? Such as the Ford Escapes that have the five speed.
May 27, 2019 at 10:06 AM
  • 55,548 POSTS
No sorry I can't. you would need to call a wrecking yard they have the software that tells all that stuff, are you thinking about installing a manual transmission?
May 28, 2019 at 3:53 AM
