Catalytic converter rattling sounds?
190,570 MILES • 6 CYL • 2WD • AUTOMATIC
MARTINFLORES
There's knocking loudly and muffler sounds loud as I'm driving and the catalytic converter sounds like something is loose inside of it.
Aug 27, 2023 at 6:06 PM
  • 55,797 POSTS
2020 GMC JIMMY? This happens when the catalytic converter is hot and then water gets slashed in it which breaks apart the honeycomb inside the converter. This means it will need to be replaced, here is the new catalytic converter on amazon for $135.00 I believe.
https://amzn.to/3qHariB
Please double check the model so I can give you instructions on how to replace it.
Aug 28, 2023 at 4:25 AM
