Will not start after cutting off the catalytic converter
198,000 MILES • 3.8L • 2WD • AUTOMATIC
DANIEL2323
I recently just cut catalytic converter off my van because it was stopped up. I put the flex pipe repair on. And now the van still won't start. Any help will be greatly appreciated.
Oct 11, 2020 at 4:33 AM
Okay. We need to start at the beginning of what causes a crank no start. Here is a guide that will help with that:
We need to use starter fluid and see if that causes the engine to start. Then we need to check for spark by pulling a plug and holding it against the block to see if there is spark when you crank the engine.
Let's start with this and go from there. Thanks
Mar 24, 2021 at 11:23 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Since your van won't start first thing to check is to see if it's getting fuel and spark. Here are a few tutorials for you to view:
If you don't have access to a fuel pressure tester most auto parts stores have a tool loaner program and can rent you one. I've attached the fuel pressure specification for your van below. Is the check engine light on ? Hope this helps and get back to us after performing these tests and we'll go from there. Thanks for using 2CarPros.
  • 55,743 POSTS
This guide will help you test the ignition spark:
