Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Sable
Engine
Symptoms
Idle Rough
Engine light stays on, idles rough
2004 MERCURY SABLE
140,000 MILES • 6.0L • AUTOMATIC
CARRIE ROBERTS
MEMBER
1 POST
Catalytic converter? Engine light stays on, idles rough
Apr 3, 2021 at 7:24 AM
Experienced Mechanic
Good morning,
There are many reasons that could cause rough running. I attached a guide for you of possibilities.
I would check the compression to be sure the engine is still good. You should have 140-160 pounds in each cylinder.
Did you have the code checked for the engine light? I need that code to help narrow the area of failure.
Apr 3, 2021 at 11:07 PM
CARRIE ROBERTS
MEMBER
1 POST
2CarPros.
Thank you for responding. I have taken it to a shop. I was charged for a leak in the manifold. Also replacing a coil. It still chokes out.
Carrie Roberts
Apr 29, 2021 at 9:38 AM
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Apr 29, 2021 at 9:39 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
