Catalytic converter
130,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
AJVENECIA
I have a P0420 code on my vehicle. So I replaced the o2 sensors and did a diagnostic. My catalytic converter temperature and o2 sensor are reading as they should, but I am still getting the code for P0420. I have another issue with my car having a rough idle and trouble starting sometimes after refueling. Is it possible that the EVAP system could be causing all the trouble?
Nov 17, 2018 at 3:04 AM
Good afternoon.
The 420 code is for a failed catalytic converter. The precious metals are worn out inside and the gases are not being cleaned.
It is never the O2 sensors as they are doing the job of monitoring the catalytic converter.
The way to confirm is to have a scan tool and monitor the voltages of the downstream O2 sensor. It should have a steady reading. If it varies like the front, then the catalytic converter is bad.
P0420
Descriptor
Catalyst Efficiency (Bank 1)
Probable Causes
Aging or Contaminated Oxygen Sensor (O2S)
Catalytic Converter
Engine Mechanical Condition
Exhaust Gas Leak
Oxygen Sensor (O2S) Wiring and Connectors
Nov 17, 2018 at 3:20 AM
AJVENECIA
The o2 sensors are reading as they should and the catalytic converter is reaching proper temperature.
Nov 17, 2018 at 4:44 AM
What are the downstream O2 sensors reading when the engine is running?
Can you post a picture of the readings? Are they steady or do they vary in voltage?
Nov 17, 2018 at 5:47 AM
AJVENECIA
Upstream sensor varies and downstream stays around .7 volts.
Nov 17, 2018 at 6:25 AM
Drive it and monitor it and see if it changes.
Also, if you can read freeze frame data from the set code, what was the voltage at the time the code set?
Nov 17, 2018 at 6:28 AM
