Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Exhaust
Catalytic Converter
catalytic converter?
1994 TOYOTA CAMRY
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
YUKONJANE321
MEMBER
1 POST
cat at full operating temperature is only 90 degrees in front and 130 degrees in rear.
Nov 7, 2022 at 1:56 AM
Experienced Mechanic
Is this Fahrenheit or Celsius? It sounds like the cat is working what seems to be the problem cold exhaust?
Nov 7, 2022 at 3:45 AM
YUKONJANE321
MEMBER
1 POST
How can a catalytic converter only be 90 degrees Fahrenheit when it's completely warmed up?
Nov 16, 2022 at 5:37 AM
Yep, it should be hotter than that. Can you test the meter on something else? Also are you pointing the meter at the inlet pipe?
Nov 16, 2022 at 5:39 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
