catalytic converter?
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
YUKONJANE321
cat at full operating temperature is only 90 degrees in front and 130 degrees in rear.
Nov 7, 2022 at 1:56 AM
  • 55,721 POSTS
Is this Fahrenheit or Celsius? It sounds like the cat is working what seems to be the problem cold exhaust?
Nov 7, 2022 at 3:45 AM
YUKONJANE321
How can a catalytic converter only be 90 degrees Fahrenheit when it's completely warmed up?
Nov 16, 2022 at 5:37 AM
  • 55,721 POSTS
Yep, it should be hotter than that. Can you test the meter on something else? Also are you pointing the meter at the inlet pipe?
Nov 16, 2022 at 5:39 AM
