Catalytic converter not ready for smog
80,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
FRANK JORQUEZ
I cannot get my catalytic converter to be ready for smog. I have no codes and I have completed the drive cycle. what can I do to get it ready?
Jan 21, 2018 at 2:23 AM
  • 31,937 POSTS
What is the actual problem? i do not quite understand what the concern is, if you have no codes what is the problem?
Jan 21, 2018 at 3:31 PM
FRANK JORQUEZ
If i'm not mistaken there are 8 codes that need to be" ready" on the OBD, before they actually hook up to the smog machine. Now i know their allowed one "not ready " code
out those codes ,however it can't be the catalyst. i hope u understand my ? better . thank you for your time..
Jan 24, 2018 at 6:03 PM
  • 31,937 POSTS
what country are you in? this may be to do with local pollution laws, where i am we do not have this concern, let me know where you are and i can direct the question to someone that may have a better understanding of this problem.
Jan 25, 2018 at 7:58 AM
FRANK JORQUEZ
Yes, I'm in Riverside Ca.
Jan 25, 2018 at 11:27 AM
FRANK JORQUEZ
I just took of the catalytic converter it seems to be okay inside has no smell to it nothing's broken inside it's all intact however there were two exhaust bolts loose on it and one of the sensors that were screwed into the catalytic converter was very very loose so I'm not sure if that's going to make a difference why it wouldn't be ready the sensor being loose in those bolts being loose putting it back together now when I'm finished I'll see what happens I'll let you guys know thanks
Jan 25, 2018 at 11:30 AM
  • 31,937 POSTS
The loose sensor can make a difference, up stream exhaust leaks will affect the cat readings, this may be all you need to do to fix the problem.
Jan 25, 2018 at 7:10 PM
