Catalyst monitoring
2008 INFINITI G35
1,660,003 MILES
SAMI1064
  • 11 POSTS
My scanner is showing me this on the catalyst monitoring section:
Lean to rich sensor (v)
Meas:5
Min:25
Max:255
Sts:fail
I would like to know if this is a bad cat or o2 sensor?
Feb 21, 2022 at 10:19 AM
Good morning,
Do you have a code that is set?
You determine a bad cat by the reading on the rear O2 sensor. Can you give me that reading?
Feb 21, 2022 at 10:41 PM
SAMI1064
  • 11 POSTS
Yes, I sure do. It’s p0420. I also smell gas when I turn on the heater, and for the o2 sensor. I have to double check. I have a cheap scanner so hopefully it gives me a reading. I will let you know ASAP.
Feb 24, 2022 at 7:26 AM
SAMI1064
  • 11 POSTS
The reading for o2S12 was 0.290.
Feb 24, 2022 at 8:26 AM
This sensor should read around.550 constantly and not vary. If it varies, then the cat is bad and needs to be replaced.
https://www.2carpros.com/articles/catalytic-converter-replacement
Feb 24, 2022 at 4:03 PM
SAMI1064
  • 11 POSTS
I went today to a shop and was told the catalytic converter at the manifold right side needed to be replaced. I also hear a pressure sound almost like a high-pressure gas gets released from the exhaust area. I saw the muffler was leaking water as well.
Feb 25, 2022 at 6:47 AM
As I stated before, you need a new catalytic converter.
Feb 25, 2022 at 6:28 PM
