Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Sienna
Exhaust
Catalytic Converter
Replace/Remove
catalytic converter
2002 TOYOTA SIENNA
135,000 MILES • 6 CYL • 4WD • MANUAL
MILDRED COTTO
MEMBER
1 POST
i just repair my car a week ago i installed the catalytic converter and the engine light back on. the code was po420. what you think i can do?
Jul 5, 2016 at 1:52 AM
HMAC300
Experienced Mechanic
the code has to be removed with a scanner if that is the problem. it can be an air leak as well in front of converter or the O2 sensor may be bad.
Jul 5, 2016 at 2:24 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
