Gears not changing
205,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
KIM PREVATTE
Replaced linkage cable,gasket,filter,solenoid,diagnostic machine read something to do with coolant temperature. so replaced thermostat and then starter went out. so replaced and gears still not right neither is temperature.
Oct 20, 2019 at 5:08 AM
Good afternoon,
What was the code that was set? I need that to help
If there is no transmission code or TPS code. good chance you have an internal failure in the transmission not allowing it to work correctly.
Did this happen all of a sudden?
Oct 20, 2019 at 5:33 AM
KIM PREVATTE
I can't remember the actual code but it read coolant temperature some then and I believe it had an 8 in the code. hope you can help. I was thinking try sensor or stopped converter.
Oct 20, 2019 at 5:35 AM
KIM PREVATTE
Pretty much happened all the sudden yes.
Oct 20, 2019 at 5:36 AM
KIM PREVATTE
I need the exact code number.
No to the catalytic converter unless the engine will not rev up in park or neutral.
Oct 20, 2019 at 5:55 AM
