Gears not changing
KIM PREVATTE
  • 2005 CHEVROLET MALIBU
  • 3.5L
  • V6
  • 4WD
  • 205,000 MILES
Replaced linkage cable, gasket, filter, solenoid, diagnostic machine read something to do with coolant temperature. So replaced thermostat and then starter went out. So replaced and gears still not right neither is temperature.
Sunday, October 20th, 2019 AT 12:08 PM
  • 52,797 POSTS
Good afternoon,
What was the code that was set? I need that to help
If there is no transmission code or TPS code. good chance you have an internal failure in the transmission not allowing it to work correctly.
Did this happen all of a sudden?
Sunday, October 20th, 2019 AT 12:33 PM
KIM PREVATTE
I can't remember the actual code but it read coolant temperature some then and I believe it had an 8 in the code. Hope you can help. I was thinking try sensor or stopped converter.
Sunday, October 20th, 2019 AT 12:35 PM
KIM PREVATTE
Pretty much happened all the sudden yes.
Sunday, October 20th, 2019 AT 12:36 PM
KIM PREVATTE
  • 52,797 POSTS
I need the exact code number.
No to the catalytic converter unless the engine will not rev up in park or neutral.
Sunday, October 20th, 2019 AT 12:55 PM
