what is a difference between cataclean diesel and cataclean gas?
208,300 MILES • 2.7L • V6 • 4WD • AUTOMATIC
EVELKA
  • 47 POSTS
can i use both for my car? thank you.
May 15, 2021 at 12:32 AM
You cannot use the diesel treatment. This is meant for diesel engines only.
The difference is in the name. One is for gasoline engines (gas) and the other is for diesel engines.
Basically these engines run on very difference combustion systems. Meaning the diesel fuel will ignite from compressing it to the point it ignites. The gasoline engine requires the spark plug to ignite the fuel.
So these engines require very different additives to clean them up so you need to stick with the one that was formulated for your engine or it could damage your fuel system.
See below for more info on each of these. As you will see the gas product states it is for any gasoline engine. The diesel is for any diesel engine and they don't say you can mix them between engines.
May 16, 2021 at 12:46 PM
EVELKA
  • 47 POSTS
What is a difference between cataclean diesel and cataclean gas? Can I use both for my car cause description says exact same thing for both.
May 17, 2021 at 5:04 AM (Merged)
Good afternoon,
One is for gas and one for diesel. The converters in each are different and the compounds that are used are feared for gas or diesel.
Rarely this additive works. It will not restore a converter to proper operation as the precious metals are the issue inside the converter.
EVELKA
  • 47 POSTS
Okay, thank you.
You are welcome.
Always glad to help.
EVELKA
  • 47 POSTS
Thank you again. wish me go cause my inspection is due soon, lol.
EVELKA
  • 47 POSTS
Thank u again wish me go cause my inspection is due soon lol
Keep us updated with your inspection.
EVELKA
  • 47 POSTS
I will.
