Cat temperature?
140,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DONNIE H
Truck running with small miss. I checked cat temperature upstream bank 1 256 degrees downstream 420 degrees bank 2 upstream 242 degrees downstream 452 degrees, is this good or bad?
Jun 14, 2023 at 10:20 PM
  • 110,248 POSTS
The temperature outside is usually between 30 and 100 degrees hotter. You are a little beyond that point, but I don't feel it is that far out. What is happening that caused you to check the converters?
Also, take a look at this link, you may find it helpful:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jun 15, 2023 at 4:47 PM
