Very dim headlights, A/C, clock light stopped working properly
110,879 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JBONE74
Well, my low beam headlights use to work but they were so dim I couldn't use them. now they both quit working along with my A/C, clock light flickers, and usually blows right rear turn signal.
Sep 3, 2021 at 7:38 AM
Good evening,
This all sounds like low voltage.
Check the battery and see if the voltage is good. You may just have a bad battery.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
I attached some guides for you to follow for checking the battery.
Sep 3, 2021 at 11:24 AM
