Will not stay running?
285,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DUMISANI22
Car starts for two seconds then shuts off.
Aug 16, 2021 at 12:18 AM
  • 110,248 POSTS
First, have you checked for diagnostic trouble codes? If not, that is where I would start.
Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
If you don't have a scanner, most parts stores will lend one to you.
Next, I would check to see if fuel pressure is within spec. It may provide enough pressure to start but not be able to keep up.
Here is a link that shows how that is done:
Let me know if either of these two things have been done and the results.
Aug 16, 2021 at 2:03 PM
