Service stability, ABS, and brake lights are on
2002 OLDSMOBILE AURORA
152,000 MILES • 6 CYL • 2WD • AUTOMATIC
NAVAGATOR31
Cars DIC message on dash reads all system. Also, brake fluid goes low.
Dec 29, 2021 at 2:14 PM
  • 110,240 POSTS
The first thing you need to do is determine where the brake fluid is going. If it is going low, there has to be a leak.
Check behind each of the wheels/tires to see if there is any evidence of fluid getting on them. Next, check under the vehicle to check if any steel brake lines are leaking due to rust or damage. Next, check around the brake master cylinder for leaks.
Here is a link that is titled "Brake pedal goes to the floor." It explains how to locate leaks.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Let me know what you find or if you have questions. Once we determine where the leak is and prevent the master cylinder from getting low on fluid, chances are the lights will turn off and stay off.
Dec 30, 2021 at 10:17 AM
