Vad kan orsaka en bil att köra trög sedan göra knackar tongångar har vit rök från motorn sedan dö och inte börja igen?
May 13, 2015 at 9:15 PM
✓Experienced Mechanic
I hope that this translates ok,
White smoke is often a sign of coolant is entering the combustion chamber, you may have a blown head gasket, you can get a cooling system head check, this is a simple chemical test to test for Co in the cooling system, if so you will have a gasket or head problem.
