Carburetor vacuum hose replacement
56,500 MILES • 8.2L • V8 • 2WD • AUTOMATIC
CADDY74
  • 5 POSTS
Where can I buy a 3 way u-shape carburetor vacuum hose for the car listed above?
Nov 16, 2019 at 7:51 AM
  • 110,248 POSTS
Hi:
That is a tough one. Since there won't be anything available from a dealer, you will need to find something aftermarket. In most parts stores, there is a "Help" section where aftermarket manufacturers provide older and more generalized replacement parts. That will most likely be your best bet.
Is it possible for you to upload a pic of the part you need? I may be able to give you some ideas for a repair.
Nov 16, 2019 at 11:25 AM
CADDY74
  • 5 POSTS
The vacuum hose with an arrow pointing to it that says black on the front of the carburetor. If I can't find one I will try a four way connector to hook all the vacuum hoses.
Nov 16, 2019 at 12:00 PM
  • 110,248 POSTS
What I would suggest is what you are already thinking. You are going to need to modify and create a new way of doing it.
If I'm looking at the correct connector, I see three connections. You should be able to get a three way connector and make it work.
Nov 16, 2019 at 12:08 PM
