Carburetor rebuild/replacement
1,000 MILES • V8
TRACYWB
Car has Chevrolet 350 in it. When I "suddenly" depress accelerator it will sputter. Gradual acceleration it runs fine. It will do this idle and driving. I was told carburetor needed rebuild. I was thinking of buying a new one. But I'm not sure what I need to fit this motor? I want max hp available. But don't want to break the bank too much. Any suggestions?
Sep 7, 2019 at 11:55 AM
CJ MEDEVAC
  • 11,000 POSTS
I really like Holleys!
Easy to jet (if necessary)
Easy to adjust.
In my region, many auto parts stores keep parts for them in stock ready to go!
Don't go overboard!
This site will aid you in selecting the correct animal for your application!
https://www.holley.com/retailer/carbselector/
Most of the time, the carburetor will arrive jetted perfectly for you. It may only need some minor tweaking using a vacuum gauge or a dwell/ tach meter.
This help at all?
See the 390 4 barrel Holley on my straight 6 258 below. I now get 18 MPG and more power than with the stock Carter BBD carburetor. (I was more after the MPGs than anything). The Holley was about $400 and the 4 barrel intake was about $250 or so.
The Medic
Sep 7, 2019 at 12:59 PM
