Carburator rebuild
150,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
LEIFERSOUTHERLAND
  • 5 POSTS
The car won't start after carburator rebuild.
Feb 27, 2016 at 4:40 AM
HMAC300
  • 48,601 POSTS
if it ran before carb overhaul then recheck all your work and measurements it can be dirt in needle and seat and or accelerator pump not adjusted correctly or choke not working
Feb 27, 2016 at 5:01 AM
LEIFERSOUTHERLAND
  • 5 POSTS
It started for a several seconds this morning. The needle seats were leaking gas so I replaced them. Now the engine isn't turning over.
Feb 27, 2016 at 5:20 AM
HMAC300
  • 48,601 POSTS
check fuses and if you have one a starter relay and check battery for condition including load test. if you hear a clunk when you try to turn engine over hit body of starter with a hammer if it starts you need a new starter.
Feb 27, 2016 at 6:09 AM
LEIFERSOUTHERLAND
  • 5 POSTS
No worries, I got it, it was the needle seats. Thanks though.
Feb 29, 2016 at 1:06 PM
LEIFERSOUTHERLAND
  • 5 POSTS
I just blew them out with compressed air. I had to repeat this process 2x. I decided to go with the older gasket because is was still in good shape, lots of little things in there.
Mar 3, 2016 at 7:08 AM
