carburetor not working properly
100,000 MILES • 2.8L • V6 • 2WD • MANUAL
MARTHA PABON
My car needs a carburetor. it is not working properly, start jumping when shifting gears and move back and forth between changes gears. Someone suggested to find a carburetor however I was told it is fuel injection.
1988
Make:
Chevrolet
Model:
S10 Pickup
Trims Available:
7
Made In:
United states
Body and doors:
Regular cab pickup 2-dr
Engine:
2.8l v6 ohv 12 v
Transmission:
5-speed manual
Driveline:
Rwd
Seating:
3
MPG:
24 miles/gallon/30 miles/gallon
Mar 22, 2022 at 2:04 AM
  • 110,248 POSTS
This vehicle should have a throttle body injection and not a carburetor. Have you checked to see if there are any diagnostic trouble codes that may identify where the problem is coming from? This truck has an OBD1 system and doesn't require a scanner to retrieve codes. All you need is a short jumper wire or even a paper clip. If you haven't checked, see if codes are present.
Here is a link that explains how it is done:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Mar 22, 2022 at 1:21 PM
