carburetor surges when stopping?
58,000 MILES • 5.7L • V8 • 2WD • MANUAL
MIKE SZCZEPANSKI
quadrajet carburetor surges when stopping or stopped from1000rpm drops to 500 rpm
Apr 18, 2026 at 2:47 AM
  • 55,711 POSTS
Yep, it will do this when you have a vacuum leak, I would check the vacuum lines at the base of the carb along with the gasket and also check the PCV valve. You should check the carb mounting bolts/nuts as well I have seen those come loose, this video will help you find the leak.
https://www.youtube.com/watch?v=LRKWV4Are5c
Let us know how it goes
Apr 19, 2026 at 1:33 AM
