Car will not start when cold, unless primed and will not idle when running?
146,000 MILES • 1.4L • 4 CYL • 4WD • MANUAL
FRANK DAVIS
Oct 24, 2022 at 12:52 PM
  • 55,691 POSTS
This can be a problem with the choke, fuel control solenoid or you have a vacuum leak. I would check for the leak first when the engine is cold only, please follow this guide and get back to me. Also, check all the fuses as well.
Please go over this guide and report back.
Oct 25, 2022 at 3:46 AM
