carburetor/choke valves
150,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
DANDEE50
  • 11 POSTS
Will not start but if I tie open bigger valves it starts and runs good.
Jul 6, 2018 at 2:43 PM
DANDEE50
  • 11 POSTS
Here is a picture.
Jul 6, 2018 at 2:52 PM
Good morning.
If you open the choke in the front or the butterfly, will it start?
You may have a bad choke pull off. You are allowing air into the system. The choke may be stuck closed causing a flooded condition.
Jul 6, 2018 at 3:58 PM
DANDEE50
  • 11 POSTS
If I remember right it is already open a little when I start it because I remember putting a little gas in it or spraying starting fluid in it to get it going. But with the back one open it no longer needs to be primed and it starts right away or as soon as I turn key. So they are both open when running.
Jul 9, 2018 at 9:15 PM
DANDEE50
  • 11 POSTS
So it is possible it might flood and backfire causing a fire? Is that what might happen? I still have not driven it yet.
Jul 9, 2018 at 9:17 PM
DANDEE50
  • 11 POSTS
And thank you for your reply.
Jul 9, 2018 at 9:18 PM
DANDEE50
  • 11 POSTS
Was trying to avoid getting a rebuilt one cause it is so expensive but maybe it is time to, to be safe.
Jul 9, 2018 at 9:23 PM
The rear should never be open unless you are at full throttle. The secondaries only open at 3/4 throttle or better.
You will need to either have the carburetor rebuilt or replaced.
https://www.rockauto.com/en/catalog/chevrolet,1985,g10,5.0l+305cid+v8,1044010,fuel+&+air,carburetor,5904
Jul 9, 2018 at 9:27 PM
DANDEE50
  • 11 POSTS
I knew something was not right. Thanks man and thanks for link too. Have a great day.
Jul 9, 2018 at 9:44 PM
DANDEE50
  • 11 POSTS
Oh and I am pretty sure front ones do just that, that is open more the faster you go so that is the working right , correct?
Jul 9, 2018 at 9:47 PM
It should open fully within about two minutes.
Jul 9, 2018 at 9:48 PM
DANDEE50
  • 11 POSTS
Got it, thanks again.
Jul 9, 2018 at 10:18 PM
You are welcome.
Feel free to ask any follow up questions. We are glad to help.
Jul 9, 2018 at 11:07 PM
DANDEE50
  • 11 POSTS
Thanks Roy, wanted to mention, I do not know what the fuel filter in the carburetor has to do with any of this but I replaced it and when I put the hoses and air cleaner back on the front butterfly valves were open and rear closed and it started and is running good again. Could be some vacuum hoses were in wrong place and I put them back on in the right way. Strange! Anyway if it goes back to doing it again I might not need a mechanic, I might be needing a priest! Have a good one and thanks again.
Jul 14, 2018 at 1:09 PM
