Stopped and shut off car. I went to start and there was no sound?
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARSHA MAILMAN
Stopped and shut off car. I went to start and there was no sound. Even the gear shift would not move. A fella said the security light flashed on. Then went out. I have been told to reset the security on the car.
Jul 20, 2022 at 11:28 PM
  • 55,616 POSTS
Do the headlights/dome lights come on? If not, it sounds like the battery has shorted out which happens, or you have a bad connection at the battery. To be sure let's use these guides to help us test the battery, you don't need equipment to do this test:
and
Please run down these guides and report back
Jul 21, 2022 at 6:58 AM
MARSHA MAILMAN
Everything still works. Lights radio windows.
Jul 21, 2022 at 7:56 AM
  • 55,616 POSTS
So, I am assuming the security light keeps flashing when you try to crank it over? This is how to reset the security system and this guide can help as well. Also, you can try to reboot the car by holding the negative cable (battery end) to the positive battery terminal for 1 minute.
This guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Immobilizer System Component Programming
10-Minute Immobilizer Relearn
This 10-minute relearn procedure will relearn the fuel continue password between the theft deterrent module (TDM) and the engine control module (ECM).
1. Connect a scan tool to the vehicle in the pass-thru arrangement.
2. Turn ON the ignition, with the engine OFF.
3. Ensure that all power consuming devices are turned OFF on the vehicle.
4. On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions, using the Legacy Pass-Thru method. Ensure the correct programming selection is chosen based on component being replaced or programmed. For this procedure, go to the V.T.D. Vehicle Theft Deterrent Learn menu and choose the Vehicle Theft Deterrent Learn for Powertrain System selection. Ensure the correct Vehicle Theft Deterrent Learn for Powertrain System selection is chosen based on the engine RPO of the vehicle being programmed.
5. At this point the scan tool must remain connected for the duration of the 10-minute relearn procedure.
Important:
* The scan tool will initially display 12 Minutes. The first 2 minutes allow the scan tool to initialize the appropriate control module. The remaining 10 minutes is the relearn timer.
* On some vehicles the security indicator may be illuminated for the duration of the 10-minute relearn procedure.
6. Observe the scan tool, after approximately 10 minutes the scan tool will display "Programming Successful, Turn OFF Ignition". The vehicle is now ready to relearn the key information and/or the passwords on the next ignition switch transition from OFF to CRANK.
7. Turn OFF the ignition and wait 2 minutes.
8. With a master vehicle key, turn the ignition to the RUN position for 15 seconds, then start the vehicle. The TDM and ECM have now relearned the fuel continue password.
9. With a scan tool, clear any DTCs.
Jul 22, 2022 at 7:16 AM
