Surging as though I was trying to move with handbrake on
30,000 MILES • 1.3L • 2WD • MANUAL
JULIE THEWLIS
It has been about ten days since my car was driven due to Christmas holidays. Today I got in my car, turned on the engine, put in reverse to get out of car park, released handbrake and the car would not move. Was surging as though I was trying to move with handbrake on.
Put handbrake on, put into first gear, released handbrake same problem, car surging as though trying to set off with handbrake on.
I decided to give it another go, but into first gear, released handbrake, car surging as before, kept foot on accelerator, after two to three seconds maximum there was a loud mechanical bang/clang noise and car moved forward.
I tried it a couple of times more in both first and reverse and car moving backwards and forwards normally.
Drove to shop and seemed to be driving okay except when braking there is a very gravelly type sound. I am pretty sure my car brakes have sounded like that after not been driven for a while in the cold/damp before though and I am just been paranoid!
Does this sound like something dangerous that I should be taking my car to be looked at for?
Thanks for any advice.
Julie
Jan 1, 2018 at 12:41 AM
HARRY P
  • 2,292 POSTS
It sounds like the brakes were frozen or stuck in place. Loud noise was the sound of them breaking loose with the pushing and pulling that you were doing by trying to drive the car. This kind of thing can happen when you have not driven the car for a while. The gravelly noise was probably due to rust spots on the brakes. If the noise stopped after you used the brakes five or ten times, then it is nothing to worry about. If, however, it persists, then you probably need new brakes pads and possibly rotors.
So did the noise stop?
Jan 1, 2018 at 2:08 AM
