Engine does not crank after a loud noise and shutting off?
2,300,000 MILES • 2.2L • 4 CYL • 2WD
CISCO LOPEZ
Was driving and all of a sudden there was a loud noise by the bottom of the steering column and now the car won't start. When I turn the key u can hear the starter but won't turn over.
Dec 19, 2024 at 10:39 AM
MECHTRIX
  • 573 POSTS
Oh no " its probably best to have it towed into a shop and get it up in the air and have a Mechanic get a good look at it .. good luck
Dec 19, 2024 at 3:44 PM
STEVE W.
  • 15,390 POSTS
Loud noise followed by no start is not a good thing. I would try turning it over by hand and look around on the engine for any damage, like a hole in the block. Did it lose the oil or any coolant? The description sounds like engine failure. If you try to rotate the engine by hand and it doesn't move, that would almost confirm it. You might be able to reach in there with a camera and get images easier than fighting to see it directly.
Dec 29, 2024 at 2:09 PM
CISCO LOPEZ
E engine turns but the starter it won't turn the flywheel, but they starter turns that there's no connection.
Dec 30, 2024 at 4:04 PM
STEVE W.
  • 15,390 POSTS
Okay, if the engine turns and the starter spins but doesn't engage you will need to get under it and see why. A loud bang could be pretty much anything, from a bad converter that shoved the ring gear out or the ring gear itself may have failed. Could even be something like the crankshaft broke and only the back of it is moving. But it's going to need a visual inspection.
Dec 30, 2024 at 5:55 PM
