Car will not turn over
234,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
GREGSS79
I took the thermostat out, reconnected housing, and tried to start the car. The engine lurched and then the starter just started clicking.
Jan 21, 2020 at 7:43 AM
  • 110,248 POSTS
Have you checked to make sure the battery terminals are clean and tight? Also, is the battery fully charged? If you are only getting a clicking, it sounds like either a bad connection (dirty, loose, corroded) or an issue with a weak battery. Take a look through these two links and let me know if they help.
I will watch for your reply.
Jan 21, 2020 at 9:46 AM
